Explanation: What would it be like to fly through the universe? Possibly the best simulated video of this yet has been composed from recently-released galaxy data from the Sloan Digital Sky Survey. Every spot in the above video is a galaxy containing billions of stars. Many galaxies are part of huge clusters, long filaments, or small groups, while expansive voids nearly absent of galaxies also exist. The movie starts by flying right through a large nearby cluster of galaxies and later circles the SDSS-captured universe at about 2 billion light years (a redshift of about 0.15) from Earth. Analyses of galaxy positions and movements continues to bolster the case that our universe contains not only the bright matter seen, like galaxies, but also a significant amount of unseen dark matter and dark energy.
Re: Interesujące miejsca "widziane z satelity"
: 24 lis 2012, o 22:54
autor: busik
coś o huraganach
Sandy z satelity od początku do końca
Explanation: Should you be worried about hurricanes? To find out, it is useful to know where hurricanes have gone in the past. The above Earth map shows the path of every hurricane reported since 1851, Although striking, a growing incompleteness exists in the data the further one looks back in time. The above map graphically indicates that hurricanes -- sometimes called cyclones or typhoons depending on where they form -- usually occur over water, which makes sense since evaporating warm water gives them energy. The map also shows that hurricanes never cross -- or even occur very near -- the Earth's equator, since the Coriolis effect goes to zero there, and hurricanes need the Coriolis force to circulate. The Coriolis force also causes hurricane paths to arc away from the equator. Although incompleteness fogs long term trends and the prevalence of hurricanes remains a topic of research, evidence is accumulating that hurricanes are, on the average, more common and more powerful in the North Atlantic Ocean over the past 20 years.
: 24 lis 2012, o 23:10
autor: busik
Link: http://www.youtube.com/watch?feature=pl ... G0fTKAqZ5g
ziemia w filmie poklatkowym ze zdjęć z międzynarodowej stacji kosmicznej. Niesamowite wrażenie robią burze i ta poświata złotawo-zielona na horyzoncie powstała na granicy atmosfery - jak w filmach s-f tzw pole siłowe
ponoć na tej stacji kosmicznej brzask następuje co...90 minut - ciekawe czy zegar biologiczny ludzi tam urzedujących się przestawia i szybciej się przez to starzeją
: 25 lis 2012, o 10:22
autor: Gump
Przyjaciele, co sądzicie o takiej zabawce :http://teleskopy.pl/product_info.php?cP ... 1bb2e18fe9
Chcę kupić Julce na Mikołaja, wiem ,że w Bieszczadach jest jeden z najlepszych terenów do obserwacji nieba, ale jak myślicie
czy to będzie dobry teleskop jak na początek zabawy w astronoma ?
: 25 lis 2012, o 10:30
autor: Konto usunięte
Gump, myślę że będzie OK.
: 25 lis 2012, o 11:59
autor: busik
Gump, będzie git
a potem niech młoda zacznie korzystać z tej strony http://www.heavens-above.com/
i będzie wiedziała gdzie patrzeć i co właśnie ogląda
: 25 lis 2012, o 12:21
autor: burat
mojemu starszemu chcę coś takiego kupić tylko ,że oglądanie z bloku może być słabe
