Nakamichi cd500
: 28 maja 2013, o 13:38
Jak w temacie radyjko w stylu safari ;)
1500zł z wysyłką
Tylko dla koneserów
9 Colour Illumination Option
24 Bit D/A Converter
0.005% (1kHz) Total Harmonic Distortion
MP3/WMA Compatible
CD/CD-R/CD-RW Compatible
CD Changer Controller
Detachable Panel
Rotary Volume Encoder
Nakamichi CD500 CD Player Section CD-DA
System Compact Disc Digital Audio
Nakamichi CD500 Error Correction CIRC Principle
Sampling Frequency 44.1 kHz
D/A Converter Type 24-bit D/A Converter
Nakamichi CD500 Frequency Response 20 - 20,000 Hz
Signal-to-Noise Ratio Better than 100 dB
Dynamic Range Better than 90 dB
Nakamichi CD500 Total Harmonic Distortion 0.005% (1 kHz)
MP3/WMA Section
Numbers of Folders Up to 256
Number of Files Up to 999
Nakamichi CD500 Number of Files Per Folder Up to 256
Number of Folder Layers Up to 8 Layers
Bit Rate
MPEG1 Audio Layer3 32-320 kbps
MPEG2 Audio Layer3 8-160 kbps
Nakamichi CD500 MPEG2.5 8-160 kbps
WMA 64-192 kbps
Sampling Frequency
MPEG 1 32/44.1/48kHz
MPEG 2 16/22.05/24 kHz
MPEG 2.5 8/11.025/12kHz
*WMA 32/44.1/48kHz
1500zł z wysyłką
Tylko dla koneserów
MP3/WMA Compatible
Detachable Panel
MP3/WMA Section
Bit Rate
WMA 64-192 kbps
Sampling Frequency
*WMA 32/44.1/48kHz
