/S/ Endless szczęki hamulca ręćznego
xbike.pl
Post 2 gru 2008, o 02:19
jak w temacie, do STi i WRX - do EVO tez się znajdą 8-)
To te fajne co to je Tommi Makinen promuje :thumb: .
Zdecydowana poprawa dzialania hamulca recznego, istotne szczegolnie w samochodach z mocniejszą centralną szperą.
699 PLN / kpl
Mamy tez klocki do STI w mieszance CCX.
The CC-X is a ceramic-carbon-metallic compound, which is developed for fast road cars to be used at high speed driving like at Autobahn with repeated braking and acceleration. It is suited for use in a power brake system with or without ABS. The CC-X is a high heat resistance compound which can also be used for circuit racing, like a sports car club race day. There is no need to change pads for such an event. The initial bite and response is excellent even at very high speed like 250-300 km/h and so also the pedal feel and brake balance.
One can often notice that the ABS system is not operating the same amount of time at hard driving with this compound because of its construction preventing wheel lock to a big extent.
The CC-X is also developed to go together with mass-produced standard discs with lower steel quality and still not wear the discs down or cause problems with heat cracks even at high temperature operations.The wear of the pad is also exceptional low, which makes for a good economical aspect. It has, just like the race compounds, a high degree of anti-water fade even if cross-drilled or grooved discs are not used. The CC-X is also developed to be used in cold weather like minus degrees and snow. The pad response is still good in these instances.
Friction average: 0.35 - 0.45 µ
Temperature range: 100 - 700º
http://www.xbike.pl - oryginalne części zamienne Subaru, Mitsubishi
Polubił: 181 razy
Polubione posty: 109 razy
Re: /S/ Endless szczęki hamulca ręćznego
Post 2 gru 2008, o 09:45
xbike.pl , coś na twojej stronie nie działa bierząca oferta :idea: zrezygnowałeś z samochodów :?: :mrgreen:
xbike.pl
Post 2 gru 2008, o 11:09
Piter 35 pisze:xbike.pl , coś na twojej stronie nie działa bierząca oferta :idea: zrezygnowałeś z samochodów :?: :mrgreen:
nie, wkrotce maly upgrade 8-)
BTW - chciałbyś coś kupic? :mrgreen:
Polubił: 181 razy
Post 2 gru 2008, o 14:28
A wiesz tak się rozglądam , napisz na pw co tam ciekawego z subru masz.
Pzd
szczur75
Post 2 gru 2008, o 14:49
xbike.pl, a jak tam lusterko? I reszta?
(bo kontakt z tobą truuuudny)
xbike.pl
Post 2 gru 2008, o 20:12
szczur75 - nie mam takiego lusterka niestety. Na razie friendy z US tez nic nie mają. No chyba, ze chcesz nowiutkie w pudeleczku to oczywiscie - no problem.
szczur75
Post 2 gru 2008, o 20:32
xbike.pl pisze:szczur75 - nie mam takiego lusterka niestety. Na razie friendy z US tez nic nie mają. No chyba, ze chcesz nowiutkie w pudeleczku to oczywiscie - no problem.
cena?
