sprzedam klocki używane w super stanie przód 8mm okładziny tył 9mm
cena 650pln z wysyłką koszt nowego kompletu na przód to 315$ na tył 300$
Ewentualnie zamienię się na komplet przód i tył ds performance, ds2500 lub cl rc5+ i podobne oczywiście pod zaciski brembo
Pytania oferty na pw
The ME20 Compound is semi-metallic and has been developed for racing and rally. It is a step up in initial bite and is more straight-forward with regards to brake power. Originally developed for BTCC Super Touring Cars where you have high traction afforded by suspension setup and tire compounds. The pedal feel and brake power is excellent and equal across the speed range with an easy modulation in all instances. With the ME20 it is possible to perform very hard and late braking into corners. As with the friction and bite the ME20 is a step up in heat resistance compared to the ME22 and it has shown a very good stable brake performance at high disc temperatures over 650 Degrees C. The wear characteristics of both pads and discs are on par with the ME22, and for cold weather and wet conditions it retains the same excellent resistance to water fade. The ME20 also reaches operating temperature very fast, although the range begins 100 Degrees C higher.
