michal
Polubił: 66 razy
Post 3 gru 2009, o 16:49
Lucjusz - nie, ten tekst mnie ani nie zachwycił ani nie rozśmieszył.
Post 3 gru 2009, o 19:02
no nie rozśmieszył ale lekko przeraził to już tak :o
Post 3 gru 2009, o 19:39
to trzeba go przekleić do "coś niedobrego" :giggle:
LouCyphre
Auto: H&H
Post 3 gru 2009, o 19:55
michal, No, bo śmieszny nie był to fakt ;-)
michal
Polubił: 66 razy
Post 3 gru 2009, o 21:37
burat, tekst przeraził Cię, że ktoś się ujarał i takie bulszity wygenerował? ;>
Post 3 gru 2009, o 21:44
Autoblog pisze: LA 2009: Lawsuit-happy U.S. kills chances for Lotus Exige Scura, but we'll get something similar
by Sam Abuelsamid on Dec 3rd 2009 at 1:58PM
[img]http://www.blogcdn.com/www.autoblog.com ... yo_opt.jpg[/img]
We had a chance to chat with Lotus USA spokesman Kevin Smith at the LA Auto Show and he shared a bit of news with us. He confirmed that while we unfortunately won't be getting the limited edition Exige Scura/Stealth that debuted at the Tokyo Motor Show, we will will get something close. The problem is the special matte black paint on the Scura. We reported on the rubberized finish at the time after talking with Lotus vehicle engineering director Roger Becker. The matte finish can be marked up, and because of process used to apply it, it's not possible to do spot repairs on the affected area.
Because of the litigious nature of America when it comes to product liability, Lotus has apparently opted not to offer the special paint job. We will, however, get essentially the rest of the car including the new wheel design that debuted on the Scura. The rest of the mechanical bits are largely the same as the Exige 260 S that we had so much fun with a few months ago. Lotus is still finalizing the spec of the new limited edition model but Smith tells us that it will be available in four colors including Phantom Black. Approximately 20-30 units will be built for the U.S. market in two-to-three months with availability in early spring.
Post 4 gru 2009, o 10:07
michal,nie, trochę to brzmi jak przepowiednia ,jak byś opisał w latach 60-tych naszą obecną rzeczywistość był byś sławniejszy od Lema Stasia ;-)
j33mbo
Post 4 gru 2009, o 15:16
wjechałem w Policję
straty forek: pęknięta ramka rejestracji
straty VW Transporter: wgniecione oba skrzydła tylnych drzwi
się kurcze zderzaczki nie pokryły wysokościami :-/
okazuje się, że za staranowanie radiowozu nie grozi nic większego niż 300zł i 6 punktów karnych
wrzucam tu, bo się śmieję ze swojej głupoty - zagapiłem się, podjeżdżając do nich na światłach 5km/h
miny zawartości radiowozu - 8 policjantów, jak po uderzeniu wyskoczyli - bezcenne :)
(wyraz twarzy mniej więcej : "gościu chyba ochu...łeś")
Post 4 gru 2009, o 15:23
j33mbo pisze: pęknięta ramka rejestracji
j33mbo, mimo wszystko pojedź gdzies na oględziny, zderzak na bank pracował skoro komuś wgniotłeś
Polubił: 188 razy
Post 4 gru 2009, o 15:35
j33mbo, A to pech :-(
Choć przyznam ,że Twój opis zdarzenia jest dość śmieszny :-)
Post 4 gru 2009, o 15:42
Piter 35 pisze: j33mbo, A to pech
Yes, yes, yes... :thumb:
Żartuję, ale ubawiłeś mnie...
Post 4 gru 2009, o 16:09
esilon ma rację... j33mbo, nie chcę Cię straszyć - ramka ramką, ale siła łamiąca tylko ramkę na bank nie jest w stanie uszkodzić drzwi! Akcja = reakcja, jak mawiał Isaak. Jak mi koleś wjechał w tył, to był duży huk, prędkośc też nijaka, gościowi i mi pękła ramka drobne otarcie lakieru na zderzaku. Po dłuższych oględzinach okazało się, że: tylna ścianka bagażnika jest pofałdowana, więc mata w bagażniku była podwinięta, klapa domykała się zdecydowanie ciężej, środkowe mocowanie zderzaka było pogięte, a sam zderzak za tablicą rejestracyjną miał mała dziurkę (więc w wycenie rzeczoznawczej pewnie leci do wymiany na nowy).. koszt naprawy wg aso to ok 2k. A z zewnątrz praktycznie nic nie było widać... Więc sprawdź dla własnego spokoju to i owo, właszcza pod machą.. czy chłodnica gdzieś nie dostała, czy jakieś węże się nie rozszczelniły itp.... :cofee:
j33mbo
Post 4 gru 2009, o 16:21
eMTi pisze:esilon ma rację... j33mbo, nie chcę Cię straszyć - ramka ramką, ale siła łamiąca tylko ramkę na bank nie jest w stanie uszkodzić drzwi! Akcja = reakcja, jak mawiał Isaak. Jak mi koleś wjechał w tył, to był duży huk, prędkośc też nijaka, gościowi i mi pękła ramka drobne otarcie lakieru na zderzaku. Po dłuższych oględzinach okazało się, że: tylna ścianka bagażnika jest pofałdowana, więc mata w bagażniku była podwinięta, klapa domykała się zdecydowanie ciężej, środkowe mocowanie zderzaka było pogięte, a sam zderzak za tablicą rejestracyjną miał mała dziurkę (więc w wycenie rzeczoznawczej pewnie leci do wymiany na nowy).. koszt naprawy wg aso to ok 2k. A z zewnątrz praktycznie nic nie było widać... Więc sprawdź dla własnego spokoju to i owo, właszcza pod machą.. czy chłodnica gdzieś nie dostała, czy jakieś węże się nie rozszczelniły itp.... :cofee:
ok, ok, przerzućcie do "coś niedobrego" .... pesymiści ;-) , żartuję , dzięki za info, nawet maski nie otworzyłem żeby zobaczyć, ale ogólnie od kilku dni chodzę strasznie zamotany
Post 4 gru 2009, o 17:35
j33mbo pisze: ok, ok, przerzućcie do "coś niedobrego"
nie no bez nerwowych ruchów , było smieszne :-) ,
ale zawsze lepiej sprawdzić
Post 4 gru 2009, o 19:15
ja rozumiem, że dobre części kosztują, ale ta cena to już chyba przegięcie... Tu chyba Az mógłby się wypowiedzieć, czy koleś na głowę nie upadł....
cosworth
Post 4 gru 2009, o 19:28
j33mbo pisze: wjechałem w Policję
Się ciesz, że teraz, a nie tydzień przed Euro 2012 - wtedy chłopaki będą tak spanikowane, że zaczną strzelać w obliczu takiego ataku :oops:
Post 4 gru 2009, o 19:31
Aleś dał czadu :giggle:
esilon pisze: j33mbo, mimo wszystko pojedź gdzies na oględziny, zderzak na bank pracował skoro komuś wgniotłeś
To ja kciuki trzymam, żeby to było czarnowidzenie :!:
Post 4 gru 2009, o 19:37
So What! pisze: To ja kciuki trzymam, żeby to było czarnowidzenie
ja też , serio 8-)
minimus
Auto: kiedyś OBK MY06 2.5L
Post 4 gru 2009, o 21:05
j33mbo pisze: miny zawartości radiowozu - 8 policjantów, jak po uderzeniu wyskoczyli - bezcenne :)
j33mbo, a jak tam Twoja mina?? :mrgreen:
Post 4 gru 2009, o 22:00
j33mbo, a tak mi jeszcze przyszło do głowy, czy niebiescy byli trzeźwi, albo czy czasami nie cofnęli Tobie w zderzak... :?
Dziwne?
Nieeeee.....
W 1983 roku, nie do końca stabilny funkcjonariusz, cofnął we mnie UAZem wew Fiata 126 z literka p...
Miał znajomych moich Majstrów, więc auto szybciutko zostalo wyklepane i przedni pas pomalowany, za usługe ktorą do dzisiaj pan niebieski nie zaplacil... :whistle:
Post 5 gru 2009, o 17:03
Biskup przyjechał na wizytację do pewnej parafii.
Odwiedził tam też szkołę specjalną. W czasie spotkania pyta dzieci:
- Kim chciałybyście zostać?
Jedni mówią: lekarzem, inni aktorem, modelką, itd.
Biskup pyta Jasia:
- A ty kim byś chciał zostać?
- Ja??? Biskupem oczywiście...
- Ale wiesz, to trzeba do takiej specjalnej szkoły chodzić!!
- Noooo, przecież chodzę, no nie?
j33mbo
Post 6 gru 2009, o 14:02
esilon pisze: mimo wszystko pojedź gdzies na oględziny, zderzak na bank pracował skoro komuś wgniotłeś
true, mieliście rację,
pod rejestracją jest takie wgniecenie, wielkości połowy jabłka
w poniedziałek jadę na głębsze oględziny
Post 6 gru 2009, o 22:56
- Kiedy przyjechaliśmy na miejsce, stwierdziliśmy, że prawdopodobnie została uszkodzona instalacja gazowa, na skutek czego mogła powstać malutka eksplozja - uważa Karczyński. Dodał, że w tej chwili policja sprawdza i wyjaśnia okoliczności zdarzenia.
Jak myślicie, kto jechał tym autem?
http://wiadomosci.onet.pl/2090752,11,ek ... ,item.html
j33mbo
Post 6 gru 2009, o 23:02
zastawiam się przez 5 minut o co ci chodzi, dopiero teraz skumałem, że do zagadki podałeś od razu odpowiedź :wall: :wall:
Post 7 gru 2009, o 12:47
Jeśli ktoś miałby za dużo szczęścia ;-)
http://agkompressoren.home.pl/pub/telefon.jpg
